Blowin smoke
04bigdaddydeace
lakeville,mn
Hello I have 04 f350 6.0 and she's blowin white smoke and overheatin.It has reacintly been into the dealership and had egr and oil pump replaced.
wpfd571
White Pigeon Mi.
yea it might, but with the smoke and overheating that would be my guess. Any coolant loss if so thats almost a dead give away. What do you have done to your truck? From what i hear stock 6.0's dont like tuners or chips usually blows a gasket
it's overheating because steam is blowing on the sending unit..
he he I said "unit"
anyway.. 6.0's are kinda notorious for this...
here's a hint..
get a head stud kit put in it
04bigdaddydeace
lakeville,mn
I sorry took so long to get back. To the answer I have had it in the shop 4 times in the last 5 mnths first work was the egr sensor then exhaust manifold gaskets and manifolds. then it was the oil pump its one thing after another.
I really don't know..
the guy you wanna talk to here on the forums is BamaSixGun
he went through this right about the time I joined...
dpantazis
#12
under the cheddar curtain
if ford is going to do the repair under warranty, talk the tech into using the head stud kit you provide, and give him a tip.
they are like $500-$600 for the head stud kit alone.
04bigdaddydeace
lakeville,mn
The work isn't under warrenty. I've shelled out 4500 hundred and I'am hoping that they cover this problem because its doing the exact same problems!
