Body Colored Door Handles
Northeast Texas
15 minutes for each rear door and the passenger side. the driver door took 30 minutes longer. it has the lock thingy arm to deal with.
but basically its a piece of cake or pie
rear door panels pop off with two screws. the plastic part that holds teh window switch POPS off and then unscrew the screw , then the door reflector pops out, remove the screw and slide the panel up and out of the way. I will look and see if anyone has a set of directions, if not i geuss a wiki is the next course.
WD40 said:
Man they sure look great. Hard to believe that they could make that much of a difference. Are they hard to take off and put the new ones on?
