Cant remember
Northeast Texas
My used crankcase oil, can i safely run it through my new 6.0 after I filter it?
it currently gets filered by teh oil guard at 1 micron. and i can filter it again when i drain it out.
my 7.3 i mixed 1 gallon of oil to fuel.
is this safe???
thanks
I know the big rigs does it all the time but the sensitive 6.0L's I dunno about :dunno
I wouldnt feel comfortable running used motor oil through the injection system on a PSD. It would almost certainly void a warranty if they (Ford) found out about it.
Northeast Texas
maybe have a high oil to fuel dilution rate and they say" boy you been putting oil in yer tank", no sir my rings leak :D :D
thanks guys
Ford_Forgotton
There are chemicals in engine oil that you can remove with simple filtering. These chemicals may or may not combust cleanly in your engine and could lead to carbon deposits, sludge, fouled injectors, who knows what.
You also dont know what chemicals will be put into the atmosphere via your exhaust when those various chemicals burn.
Waste Oil Heaters, incinerators, and some older multi-fuel rigs can run on it fine, but a direct injection, electronic diesel? I wouldnt highly recommend it.
