changed hvop and now have haveno oil pressue
The Dude
langley b.c.
My rear seal was leaking like crazy so I put a used hvop in,and now I have low amounts of oil coming out the oil line if I disconect it at the oil rail!!! could it be my ior??? need help!
strokin'_tatsch
death row inmate #7
Austin, Texas
you sure that you got the gear on the HPOP seated correctly??? if so i would venture to say that your HPOP that you got isn't in good shape.. if it ran fine before you changed it, but just had an oil leak then my guess is the HPOP.
94f450sd
certified nutjob
plymouth,ma
did you replace the orings on the IPR?make sure the bolt for the gear is tight as hell.its going to take a little time before it fires after replacing the HPOP,it needs to refill the reservoir,pump and lines.then it needs to work all the air out as well.i have had trucks take forever before firing up after a pump swap.
The Dude
langley b.c.
got it runnin!! what a pain in the rear! it took forever to fire, like all weekend! my 2003 fired up in a matter of a minute!
