Ford_Forgotton
CHPMustang said:My vote is repeated heat cycling and vibration does it.
Bill
You've got my vote on that!
Bill
The last 3 CPS' I went through the mileage on the trucks was in the 90-129k range,thats'a lotta heat and vibration a small component like the CPS can handle.Ford_Forgotton said:You've got my vote on that!
Wow thanks for giving me somthing to worry about, I just rolled over 90k. I need to pick up a spare and keep it and the tools to switch them in the truck. Might as well be prepared.CHPMustang said:The last 3 CPS' I went through the mileage on the trucks was in the 90-129k range,thats'a lotta heat and vibration a small component like the CPS can handle.![]()
One of these days I'll pick up a spare from dale for the glovebox alsobigdaddyTank said:Wow thanks for giving me somthing to worry about, I just rolled over 90k. I need to pick up a spare and keep it and the tools to switch them in the truck. Might as well be prepared.
CHPMustang said:One of these days I'll pick up a spare from dale for the glovebox also![]()
RazzyB said:In the last two weeks (oddly, warm thursdays...) My truck hasn't wanted to start at work. No tach reading when cranking.
After 10min wait, Bertha fires up again. So I'm thinking, CPS eminent failure, correct?
So, of course, as we all know, the surest-fire way to get your vehicle running is to call your wife, wait 30 minutes for her to show up, and re-attempt to start the truck - the Wait to start light came on, and she fired up. (Wife took it well, thank goodnessRazzyB said:In the last two weeks (oddly, warm thursdays...) My truck hasn't wanted to start at work. No tach reading when cranking.
Well, since that time, she has started acting up again, especially on warmer afternoons or when engine is warm. Seems to start after about 10 minutes.
I'm not sure, since I have a brand-new CPS, that that is the problem... here are a couple of observations:
- if I crank immediately after the wait to start light goes out, she won't start - I need to count to 10 or so after that, and even then it's becoming iffy
- wait to start light (and, oddly corresponding chime (x5) does not come on during most of the failed attempts
- cold starts seem to be fine (<55 deg F outside)
- the oil pressure idiot gauge doesn't register until after ~1 sec. of cranking
Could this be a fuel pressure issue? GPR? Anyone have any ideas? Truck has new CPS, new alternators and new batteries. The starter sounds strong, she's just not kicking in!
), and could not think of any reason why the WTS light would function intermittently. He ran the scanner while the truck was running, and the ICP, MAP, BARO, PCM, etc. all were normal. All he could recommend was to return the chip to stock
and drive it that way for a month.
