Question Cruise Control
fxdwgi
Global Warmer
Michigan
I replaced the VSS (Vehicle Speed Sensor). Still no cruise
I have taken steering wheel airbag apart & shop some WD40 in there & the cruise worked for a little while, does that mean the clock spring is not working, & how do you take the steering wheel off, what kinda puller do you use, also is there away to adjust the clock spring?
Thanks guys
Clockspring is bad.
tbtrammell
mountain view, ar
yah, on my 00 the cruise done exactly what your describing, turned out to be the brake pressure switch on the master cylinder.
tbtrammell
mountain view, ar
yah, don't know anything about recall wire, but when i went to my local ford dealer to buy the brake pressure sending unit they told me it was in recall, they wanted me to wait about two hours so they could do the install, but i told them i'd put it on my self. it took about 10 minutes to install.
