Nov 18, 2006 #1 L Lord Tauk Full Access Member Joined May 13, 2006 Messages 141 Reaction score 0 Location Maryland Just curious, what do you guys use/do to clean out the housing when replacing gear oil/adding a new cover?
Nov 18, 2006 #2 J jvencius Full Access Member Joined Apr 6, 2005 Messages 1,355 Reaction score 0 Location In a van down by the river... Lord Tauk said: Just curious, what do you guys use/do to clean out the housing when replacing gear oil/adding a new cover? Click to expand... I used a shop rag
Nov 18, 2006 #3 L Lord Tauk Full Access Member Joined May 13, 2006 Messages 141 Reaction score 0 Location Maryland Anyone ever use any spray cleaners? Such as brake cleaner? Then clean it out with rags, air?
Nov 18, 2006 #4 atk Moderator Joined Nov 12, 2006 Messages 2,874 Reaction score 0 Location simcoe, ontario, canada i usually try and get the most of the old fluid out. i have used brake clean or even varsol. then what is left i soak up with a shop rag.
Nov 18, 2006 #5 L Lord Tauk Full Access Member Joined May 13, 2006 Messages 141 Reaction score 0 Location Maryland Cool, thanks Atk. Just gathering some ideas to get fluid out the best if someone else has a better idea other than what I mentioned.. I've used brake cleaner myself.
Nov 18, 2006 #6 atk Moderator Joined Nov 12, 2006 Messages 2,874 Reaction score 0 Location simcoe, ontario, canada the cleaner, the better. doesnt contaminate the new fluid as much.....
