Differential question
Lord Tauk
Maryland
Just curious, what do you guys use/do to clean out the housing when replacing gear oil/adding a new cover?
Lord Tauk
Maryland
Anyone ever use any spray cleaners? Such as brake cleaner? Then clean it out with rags, air?
atk
Moderator
simcoe, ontario, canada
i usually try and get the most of the old fluid out. i have used brake clean or even varsol. then what is left i soak up with a shop rag.
Lord Tauk
Maryland
Cool, thanks Atk. Just gathering some ideas to get fluid out the best if someone else has a better idea other than what I mentioned.. I've used brake cleaner myself.
