DP for 97 PSD
Diesel Kinevel
97 Stroker
Frederick Co. MD
what would the difficulty level be to install a DP on my truck. Ive done some research on them and found a 2 peice design to help with installation. is the 2 peice known to leak? The reason Im asking is because I want to do the whole exhaust from the DP back and need to get the parts together
hheynow
Señor Aceite de Soja
Northern California
My two piece downpipe from DPPI does not leak. The accu-seal clamp is great. Two piece downpipes are easier to install than the single units are.
Two piece units work fine, I had to slot my pipe though so I could get enough compression out of the clamp to keep it together.
caryt
Wellington Nv.
You can get it all from Dale @ Tymar...Home of Tymar Performance. 509-922-8785
cary
