DP tuner VS Six gun
twt
Glasgow ,Ky
Hi I have a Banks 6 gun now that I run in # 2 position. I get about 14 - 15 mpg, not pushing it. What can I expect (real world) if I change to the DP tuner? I would like to hear from 7.3 owners. My truck has 145k on it & I have never gotten better than 16 mpg. At $4.00+ a gallon it is getting expensive to drive. Thanks for the info. Tony:dog
dpantazis
#12
under the cheddar curtain
twt-
depends on you truck. 2wd? 4wd? reg cab? long bed?
i can not comment on the banks, only the DP tuner. i 'researched' long and hard before buying chip before i decided on DP tuner. my 2000 SC LB 4x4 toppered truck gets 18-20 unloaded on the highway if i keep it around 1700-1800 rpms, running jody's 80hp econo tunes. city is 14-16.
JRJ04
Houston, TX
you should get better from the dp tuner because it is custom tuned for your truck. banks is just a generic program that does not specifically apply to your rig.
Diezel Dawg
vvv Real NW Truck
Spokane Washington
I second this! dump the Banks and get Dp-Tuner, u will not be disappointed
aklim
Hartford, WI USA
Isn't that Banks thing the one that hooks into the ICP to fool the PCM? If so, I'd ditch the b1tch and get a DP-Tuner
twt
Glasgow ,Ky
Thanks for the info I will call about a DP tuner today. Anyone want to make a bid on a Banks 6 gun??:clap:
