Dual alternator conversion??
Good point Bags, I never had to replace the aternator on my Jeep (V-6 transplant) and I had all of the electrical toys and then some. We would weld using a couple of batteries if we had to. Anyway I used a 90 amp Cadallic unit that is still running just fine. I sold the Jeep in 1986.
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
The redundant theory like airplanes have. Having two, in case one fails you have a backup.
I understand and appreciate your point of view and fully understand your above statement about redundancy since I spent over 13 years flying on B-52's. With 8 engines, at least a dozen hydraulic pumps, 4 generators and god knows how many fuel pumps, the "BUFF" is a case study in the concept of redundancy.
The units where I was assigned always had both B-52 bombers with 8 engines, and KC-135 air refueling tankers with 4 engines. Having 4 or 8 engines gives one a large comfort factor knowing if you loose one or 2 engines, there are still enough left to keep you in the air and get you home. But because B-52's had twice as many engines as KC-135's, the guys from the engine shop always spent twice as much time changing engines on B-52's vs KC-135's.
The point is that you could have a hundred alternators and never have to worry about being dead on the side of the road for lack of electrical power. But you'd spend all your time changing alternators, one here, two there.
Redundancy is great, but if you double the equipment, you double the maintenance. One just needs to make sure the equipment, or in this case, a single alternator is up to the task at hand and has the capacity to do the job.
whatabudro
Launched
DaveBen said:
I have emailed them and requested a price on that beast. I will let you all know how much this big dog is when I find out.
Dave :D
any word yet Dave?
Wood County Tx
Tail_Gunner said:
FWIW: They show a monster alternator where the frame looks about 1/3 again larger than the big frame alternator that comes on the truck standard, but still has the same mounting bolt pattern. It is a MITSUBISHI Dual Rectifier unit.
You can see the picture of the BIG ASSED ALTERNATOR here. Our standard single alternators are supposedly like the one in the middle of the three shown.
that thing is HUGE, it says it MAY fit most with the three bolt mounts???
HARLAN EMS
KENTUCKY
dual alternators
just thought i would chime in all ambulances that i know of come with the dual alternators equiped, so if you can find one around your year model at a junk yard there should be your parts and pcm. Should eb able to pick up ata fraction of teh cost just thought i would post this incase u ahvent went that route
