Dually wheel change
lifted_up
TractorMan
Drippping Springs, Texas
I have a 2000 F350 CC Dually 4x4 with an 8" Superlift and Pro Comp 315/75-16's. I want to put bigger tires but have had serious wear on the centers of these. I have a 2" spacer on the rears so I have room to grow still. :thumbs Is there an aftermarket wider wheel? :confused: Has anyone had a good large tire setup that you can share? I'm going out now to install a truspeed module and a dual steering stabilizer. Hope to hear from you when I get back. :cowboy:
Fire1
Certified Diesel Driver
Oh come on,go on and get the 22.5 or 24.5's. Don't go cheap on us :roflmao .
I was talking to tire & wheel dealer the other day and he said that any wheel over 20 inches wouold be too heavy for any vehicle. He had seen worn out ball joints and tie rod ends from them. I have never had anything approaching 20" diameter, so I would not know. After lifting the 22 inch wheel I can see why.
lifted_up
TractorMan
thanks guys. I finished the install of the Truspeed in just an hour and using a GPS it is dead on. The dual shock steering stabilizer went on with no problems either in just less than an hour. Okay, here's a new question-what is your favorite tires in 315/75-16 ???
minerwelder
