Question Elecricial bug
mr slate
MR SLATE
Bellvue Co
Hi everyone I'm the FNG. I have a electricial bug in a 2003 F350 4x4 crew dually. At time my radio will quit or not come on when ignition is on, also windows will not work and map light doesn't work. Have changed GEM module switched relays in fuse block. CAN ANY HELP OR HAVE SEEN SAME PROBLEM????????? MR SLATE COLORADO
:welcome4 FNG, Mr Slate. Hope your problem gets corrected soon. Fill out your signature by going to the Quick Links in the BLUE LINE above and click on Edit Signature. Tell us what you drive and any mods you have. This will help us help you.
Dave :)
Just looked at both wiring diagrams, and the common point appears to be a ground point behind the center of the dash.
I'm pretty sure the radio has to come out and the lower trim panel has to come off (you'll be removing the ashtray and cup thrower as well) to access it.
mr slate
MR SLATE
Bellvue Co
Thanks i'll look towards this fix. Someone else told me it might be a floating ground. I've never heard of this before and didn't know where to look . Mr slate
airdrew99
Living for Him
Brandon, MS
Mr. Slate,
On my 2000 F-250 (yours may be different), I just found a spot where rain was leaking inside my truck and dripping directly onto my GEM module and fuse block. When I unplugged the two wire harnesses from the fuse block, both had water in them. I found my fuse block to contain rust/corrosion inside. A few days ago I took apart the fuse block (one layer at a time) and bead blasted it to clean up all the rust. The rust caused my interior relay to chatter off & on for a few months before the relay gave out. Now that the fuse block is clean inside and a new relay is installed, everything works great. Just something to look at.
Drew
Dogman
tampa,FL
A good test would be to put another ground to the radio and see if the problem goes away.
bigrigr
Real trks hv 3 pdls
provo, utah
i think there was a technical service bulletin on this at ford, seemed like the windshield leaked or something. Check with ford first, they may know what the fix is right off the batt. Seems like they were replacing the fuse box or something....... just a thought.
Svttim
