engine swap?
MUDWHISTLE
Diesel Lover
oregon
How much time does it take to swap and engine out of a 97? also does the front cli have to come off or just the radiator? thanks lee
94f450sd
certified nutjob
plymouth,ma
it should take azbout 9 hours or so depending on mechanical skill.the nose does not need to come off.while lifting the motor you need to turn it a little for it to clear the firewall and radiator support.dont even need to disconnect the AC lines either.the second time i did mine i had the motor out and on the ground in about 3 hours.
MUDWHISTLE
Diesel Lover
oregon
thanks I'm worked on it about 2 hours last night and I don't have that much left.
MUDWHISTLE
Diesel Lover
oregon
right on rich thanks, Hey what is the torque spec on the flexplate bolts and the torque of the converter to flexplate nuts?
94f450sd
certified nutjob
plymouth,ma
that i dont know.i tighten them by feel.but ill see if i can find it for ya.
