viper5035
excessive oil consumption HELP!!!!!!!!!!! Update
ok here is goes, Wed morning was about 20 deg out, did not plug truck in it started and ran fine. i let it idle for a minute and then about 2 blocks of driving was at idle because it was downhill residential area. turned onto the highway and went about 2.5mi down the road lost power and pulled over and died. got it restarted and was fine after that for the rest of the day and ran normal. Thursday about 15deg out not plugged in, started rough ran rough and had a bluish grey smoke thought ok its doing that because it is so cold. died about 1 min later got her started again and was fine the rest of the day and ran normal. friday morning 10 deg out had her plugged in and started like a champ and ran great almost all day got home and she was idling rough checked oil and figured i would be about a quart low cause that is about average burn off for a 5kmi oil change interval since i owned it and she was about 2 GAL LOW so i filled her up and went for a short test drive and everything seems to run fine. I do my own oil changes and i was due in about 500mi. there is the story
now i checked for any visual leaks cant find any havent pulled anything off cause my tools are at inlaws and it was cold as **** today and cant fit in there garage.ooh and when im driving there is no smoke out the exaust. its like someone is f-ing with me and drained some oil out of my truck, i do have a fumoto valve so it wouldnt be hard to do.
so where in the hell is it going
