F250 Front Ends
ScorpionBoy
CO
Hi all,
I searched around but didn't really see what I was looking for, prolly just don't know what term to use. Anyway, I had heard that the front ends on F250s were problematic, like they were some sort of weak d50s or something. I doubted it, but wanted to check with some experts.
Hoss 350
My GSP, Dutch
Spokane, WA
ScorpionBoy said:
Hi all,
It depends on what year truck you are talking about. The '94-'97 Models of the F-250 had a Dana front end tied to an independent I-beam-type suspension. I am not at all impressed with this suspension system.
The '98-on Superduty pickups had solid front axles which I have heard nothing but good things about. They are Dana units, also, but the number eludes me. IIRC the 50 was what they called the IFS in teh older models, and the newer models are a 55. (Someone please help me, I cannot remember and am probably wrong).
Long story short, the actual AXLE AND DIFFERENTIAL units on any model year with the Powerstroke Diesel in it were very good units that were not particularly weak. The IFS front suspension in the older models, while not ideal in a lot of ways, was certainly not weak by anybody's standards.
I can only guess that the person you heard this from was a Dodge or Chevy guy spreading misinformation... :dunno
Wood County Tx
my 92 f250 HD had a dana twin traction beam. it was very stout, i beleive it was also a 50, but 44 comes to mind but 50 is the right one. it had auto locking hubs, rode rough as all heck, see ost below i did have some brake rotor stuff done under warranty
only had one set of brakes seize up on em for over 118k
Wood County Tx
I replaced my front leaf spring bushings around 80k.
it also had teh one piece hub and rotor assembly. they got replced a few times under warranty for warping of the rotor all under the three year 36k mile thingy
my above post I meant major things like bearing seizing or dependablity was great. brakes are just a wear item, so i dont usaullly rember them
your2slow
Roanoke, VA
The ball joints are the only "weak" link to the front end from what I've seen. Once you switch those over to a greasable Moog they should last a considerable amount of time though under normal driving conditions.
ScorpionBoy
CO
Thanks all! I think my source was confusing the ttb with solid axles or something, even though we were talking about (or at least I was talking about) 98+ with solid axle. So, now I can shop happily for my 250. Are there some favorite stalking grounds for finding trucks around here?
Wood County Tx
speaking of ball joints and tierods.
my 2002 had greaseable tie rods, my 2006 does not. geuss they are good forever:roflmao
JeffHK454
Cincinnati
99 and on have had lots of trouble with ball joints and those #@$!% unit-hubs! If you own a 99 or on SD and you have not put unit-hubs or b-joints on your truck your lucky.
I forgot, hello all ! New to this board and I love it!
The CPS thread saved my A$$ last night!!!
Thanks , Jeff
gquad41
