Fault codes
hammy
Hey I am having troulbe with these code dose anyone have some ideas.
P0603 Internal control module kam error
P1118 Manifold air temp. sensor curcuit low input
P1247 Turbo boost perssure low
Low boost is no problem but can the other two faults cause hard starting or no start.
bdrummonds
Maximum Overdrive
Millbrook Al.
What tuner do you have? the KAM code means you have had the batts unpluged. KAM stands for Keep Alive Memory.
The 1118 means you have either done the AIH delete or it has possibly shorted. Or since you are also throwing a Boost code, check to make sure that the AIH has not come loose .
hammy
Thanks for the info. I just did the batts and I will check the aih and wiring.
hammy
well I found a plug off on the turbo and the hard start problem was a bad injector. Who would of though that would cause a hard start.
i have a superchip in mine and the p0363 means nothing more than "you have a chip in your truck"
bdrummonds
Maximum Overdrive
Millbrook Al.
actually it means
P0363= Misfire detected -fueling disabled
which basically means the superchips has got your inj. timing so advanced that the PCM no longer recognizes the map it is running.
hammy
Hey guys . Well it has been a week since I did my injector. Go to start my truck to day and lots of smoke but no start. I have replaced the glow plug and solenoid. Is there any thing else is the curciut that would cause a hard start like a sensor ?
CSIPSD
Bend, OR
What lead you to believe that you had a bad injector? What other tests have you run? Your jumping big leaps to start replacing hard parts now...
I apologize, i think its p0603 that tells you you have a chip, not what i had previously said
castellscl
