FICM Repair
SootPowered
Esto, Florida
Keep this very very close to your hearts. These part # are a pain in the a^& to replace if you happen to misplace one. Good luck Gentleman. :sweet
From DigiKey.com
The 4 fets for the power supply 568-6993-1-ND
The 4 fets for the main board IPD70N10S3L-12CT-ND
The 8 capacitors (4 of each) P11246-ND , P11276-ND
From mouser.com
The resistors marked DALE R0075 on the poower supply 66-ULRB1R0075FLFSLT
The tiny 0805 resistor that replaces the existing resistor near the capacitor where everybody solders a normal resistor: 754-RG2012P-1821-BT5
Those are all the parts needed for the 58v ficm. I had to order a resistor (dale r0075) because I lifted one. The 0805 resistors are not needed if you just want to use the piggyback resistor.
glassauto
Scott La
SOOT
I just wanted to purchase the board already built and just swap it out with a new one you know where to just get the boards
snicklas
Super Moderator
Staff member
Greenfield, Indiana
Woo Hoo.... I am once again turning diesel into noise and movement!!! It was the FICM. FICMFixer.com seems to have done a good job on it. I shipped it out last Friday afternoon, and it got back today. Put it back in, and replaced everything I had to move... and it fired right up!!!!
Dogman
tampa,FL
These guy are good, I have had a few guys here use them with know problems.
Here there web site;
http://store.allcomputerresources.com/fordficmrepair.html
Product Description
Trust the Automotive Computer Professionals to repair your Ford FICM 6.0L Powerstroke Module....
We Repair & Rebuild your Ford FICM (Fuel Injection Control Module) for $149. Upgrade to 58 volt (40HP Increase) for just $15.
It's easy as 1, 2, 3...
1) Remove & send your FICM to our Rebuild facilty. (Instructions will be emailed after purchase w/FREE 2 Way Shipping!)
2) FICM is repaired and shipped back to you in 24-48hrs.
3) Install your newly repaired FICM and drive away.
Absolutely no programming needed! It's that simple!
*** Common issues when you have a bad FICM (Fuel Injection Control Module)***
No start/Rough Start condition, low voltage on injectors and following codes;...P0611, P0264, P0267, P0273, P0279, P0282
CALL NOW for the lowest price guaranteed!
Toll Free - 866-699-5230
Mon - Fri 9am - 6pm EST. Time
All Computer Resources Sales Department..
Kenbo11
