Firestone Ride Rite leak
Lynden-Jeff
Landscaper
Hamilton, Ontario
Hey,
Got some Firestone Ride Rite airbags for the front of my F250 and on both sides there is an air leak at the push fitting where the air line goes in. The line is cut perfectly square and is pushed in all the way. What else can I do to make them not leak?
Cheers
Jeff
Zookie400
I WANNA GO FAST
wallingford, CT
what did you cut it with? wire cutters squish the end and it tends to not seal very well. if you cut it with a razor blade it leaves the end nice and clean.
it may not be pushed in entirely, sometimes those have a step that you really need to push through.
if it comes down to it, you can replace those crap pushlock fittings with a nut and ferrel style brass fitting.
if it comes down to it, you can replace those >[crap pushlock fittings]< with a nut and ferrel style brass fitting.
X2 ;tu
Operative phrase in Brackets.
I replaced those fittings with Compression fittings and have had NO air press. issues in 100,000+ miles.
(With the exseption of Winter/Summer air temp driven diff's of course)
Zookie400
I WANNA GO FAST
wallingford, CT
any large truck dealer should carry them. those plastic airlines are the heart and soul of newer class 8 trucks, and have those fittings all over the place. if you take the plastic fitting out and bring it in to the parts counter they should have exactly what you need in brass.
woofer700
Diesel is cool
S/D
should be able to find the parts you need at your local home improvement store. menards, Lowes, home depot.
Kyle90720
