Fixing the gel coat
RoyBoy
Diesel Dork
central WI
Where do you get that stuff? Was your gelcoat totally gone, as in you can't restore it with wax/ polish or buffing? My 02 5ver needs a makeover.
X2.
Had to remove the front cap graphic on my 5r.. whata PIA the glue was !! GooGone and denatured alcohol, 3 days labor...
Needs a Shine now.
Dogman
tampa,FL
Poli Glow Products, Inc.
www.poliglowproducts.com
(800) 922-5013
Go to there web site check it out.
When you order get the poli ox too.
I tried the wax thing and it would not stay, looked good for a week or two then back to the no shine. Yes my gel coat was just starting to have hair and cracks thats how bad mine was.
If your going to put a decal back on wait they wont stick to this stuff also trim any rolled edges off too.
All in all I really like the out come. They say you need to do it one a year but you don't have to scrub it to the gel coat, just clean and reapply over the old coat.
(800) 922-5013
>WOW< Dogman, thanks.. this stuff Really WORKS GOOD. Much, much better than anything I've tryed so far. :sweet:sweet
Followed the directions (I hated doing that:sly), did the Poli Prep scrub.. That's some powrfull stuff.. didn't want to put a graphic/decal back on, so I hit the graphic shadow with some 300 grit sandpaper, per the instructions (still hated doing that:sly).. did the prep scrub again.. Let everything dry for 30 minutes. Then did the 6 coats of Poli Glow. As the coats went on.. the graphic shadow has basically disappeared.
The front 5r cap looks BETTER than Brandy New !!!!!
I like the "Wet Look". The rear cap is next.
RoyBoy
Diesel Dork
central WI
Joe as soon as you get yours all done I have a 35' and 2 kits all ready for you to make it shine! :D
Shoot a couple of Photos Joe. I would like to see.
I'm guna put one more coat on in 48 hours (Friday-ish) Dave.. then I'll post some Pics.
No Problem Royboy ;tu. $15 bucks a foot per.. you pay for the Dezel from Cali and back.. plus a 50 amp, water and elec hook up while I'm there.
jus' le'me know when you wan me to be there...... :lmao:lmao
dserge66
