Guinness
superdudiest
What I thought was a starter problem turned bad when I got a new starter and it still would not engage the flexplate. In the last mile I had driven the truck before this mess I noticed a bad vibration when decellerating down a hill while slightly on the brakes, enough for me to let off which made the vibration stop. I decided I was going to check it out on my way home but the truck would not start (starter grinding flexplate)
Im leaving friday for a vacation 5 hours away and went to put the starter in tonight when I found the trouble, I tore into it right away and dropped the trans/transfer case and found the flexplate had several cracks almost to the outer edge and the center section almost totally disconnected.
I have a few questions that will help me fix this right since it has to be done tomorrow night or atleast parts ordered for me to install on wednesday. On the torque converters nose there is a bushing about 1/4 inch wide that fits over the nose, it looks a little chewed up and the torque converter nose itself looks pretty bad off (scored and grooves in it, but not through the metal) Should I replace this bushing? I cant afford to replace the converter or the vacation is screwed. But I really cant afford to stranded on the side of the road going there.
