fuel filler neck
karpenter5
douglasville,ga
I just discovered a fuel leak on the rubber fuel filler neck. I was wondering if there is some inexpensive way to fix this problem. The dealership wants 116$ for the part I dont have it right now:dunno. Any ideas would be appreciated
Is it the rubber hose? If so you might be able to get some hose the same size at a rubber/hose supplier. Be sure to get some that is compatible with Diesel.
that seems to me to be an easy junk yard part check and see if there is a different hose for the gasoline F-series trucks if not then it'll be an easy part to get in any junk yard that doesn't yank the tanks out before they throw them out in the yard.
BriannaDawley82
