Fuel Milage
rkelly04
FORD MAN
Denver Colorado
Just installed the superchip-no matter what mode we set it on,my fuel milage went from 13.9 to 9.9 while towing my 5th wheel trailer..is this normal? Please respond...I'm at a loss.
Wow, that is unusual. What supporting mods have you done to the truck besides the SCMT? I regularly get 12 to 14 towing my 26' TT while set in the tow safe mode and in the tow extreem mode while not towing I get 17 to 18 regularly.
rkelly04
FORD MAN
Denver Colorado
The only other item I have put on is a MAC cold air kit. Other than that everything is stock. Weight or truck & trailer is about 17,500#.I also installed the 3 guage piller pod.
Well, being that you are in Denver and most likely tow to the mountatins. EGT's on a good long grade of 1300° wouldnt surprise me. With your foot buried in it your boost should be 25 lbs. But on the flats at highway speeds you should probably be 850-900° and maybe 7 or 8 pounds of boost.
Some other question as well;
How is the truck performing unloaded?
How bout unloaded MPG?
Can you feel a seat of the pants increase in power since installing the SCMT?
Getting any unusual smoke either while towing or unloaded?
Tbar
SDD STAFF/Moderator
I will approach it from a different angle..........
When was the last time you changed your oil, oil filter, air filter, fuel filter..............etc?
Tbar
