dpantazis
#12
Greetings all-
I was hoping to shim my FPR this weekend. I was also hoping to add an underhood guage to monitor the pressure. I was hoping to get some input and some comments on my concoction.
I have 'borrowed' an image from the powerstrokeshop.com of the fuel filter assemby-
http://www.trademotion.com/partloca...catalogid=3660&siteid=214083&categoryID=73730
1. So the plug marked "606819C1 Connector" is the scheader valve to get unscrewed and a grease gun hose to get screwed in?
I was going to use a glycerin filled gauge and a length of grease gun hose and a couple of fittings.
Here are the parts I was thinking of using from McMAster Carr, mcmaster.com - (mostly because they are close and i have an account)
2. Anyone have any thoughts or comments on my approach?
3. Do we have to bleed off the pressure of the fuel system before we open the filter housing or remove the regulator? If so, how? Spraying geysers of diesel would not be fun.
Thanks
Dennis
3850K24, Glycerin-Fill 304SS Case Gauge 1% Mid-Accurcy 1-1/2" Dial, 1/8" NPT Male Bottom, 0-100 PSI
2044K41 , Standard Flexible Extension Hose 12" Length
Thanks
Dennis
