Fuel problems
IDSTROKER
Blackfoot ID
Blackfoot ID
Drove the Truck today ran just fine going to town coming home it was like running out of fuel toped off tank went to start no start wife towed me home with the new F150 :( no fuel in the fuel bowl i have fuel going to the pump but nothing after that I'am assuming that the fuel pump took a crap. Any suggestions:dunno
Tbar
SDD STAFF/Moderator
Did you run it out of fuel...........how much fuel did you put in to fill it???
Tbar
Tbar
SDD STAFF/Moderator
How did you determine you have fuel getting to the pump????
Tbar
IDSTROKER
Blackfoot ID
Blackfoot ID
I unhooked the feed like to the pump and used the shop vac presured the fuel tank fuel was going in the bucket stop hooked it back to the pump presured up fuel tank turned on the key with the fuel cap removed and still not getting fuel the pump moter is running but no fuel pumping
Tbar
SDD STAFF/Moderator
In my mind there is no reason for no fuel at this point.
Are you sure you hear the fuel pump running and not the vacuum pump.
If it is running maybe there is an obsturction either in or down stream of the fuel pump.
Some one else chime in here..........I am running out of ideas.
Tbar
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
Many moons ago, I was running out of fuel with about 1/4 in the tank. I added some more fuel and it started running all right again.
I suspected a sucking air condition and decided to do the "Hutch" mod.
I dropped the tank and removed the pick-up assembly. As I went to grab the rubber intake on the bottom of the assembly, it literally fell off in my hand.
My point is that if they can come loose so easilly, maybe it's possible your's is loose and up against the bottom of the tank, sucking more tank bottom than fuel.
IDSTROKER
Blackfoot ID
Blackfoot ID
Mine is not sucking any fuel at all but if I presurize my tank fuel comes pouring out with the feed line unhooked from the pump
