Fuel problems
IDSTROKER
Blackfoot ID
Blackfoot ID
Well just got new pump will install late tonight and let everyone know how it turns out hope that it works out
Just to be sure you don't have any restrictions.. Open the water drain valve on the filter, Then, turn the key on (with yer new fuel pump) and watch for fuel from the drain valve*.
If no fuel flow ? Put Shop-Vac pressure on the fuel tank. If you then see fuel flow... you've got a restriction in the tank, prolly the Duck Bill pick up valve.. Like TG sez.
* It may take some Shop-Vac pressure to initially prime the pump.
IDSTROKER
Blackfoot ID
Blackfoot ID
Fuel pump $288.31
1 Hr Labor $ 55.00
Truck running PRICELESS
Thanks to all of you that help me with my truck. Truck run's even better then before.Thank's again
