Future Super Duty updates
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
A better paint job and improved corrosion resistance. I had rust coming through the paint after only two winters. It's been an ongoing battle ever since. I finally had to spring for a total repaint about 4 months ago. -mad
After seeing how well Fords hold up corrosion wise around here, I'm wondering if Ford's corrosion testing facility is in the Arizona desert. :rolleyes:
JIM_C
Turbo Lover
Tucker, GA
Fix the roof so that condensation doesn't drip onto the power door lock and window controls when I roll the windows down in the mornings
JIM_C
Turbo Lover
Tucker, GA
jvencius said:
I've got stick-on Ventshades and they do a good job of stopping that.
How's the wind noise with those? And will they cut into my budget for X-springs and a Ranch Hand?? :confused: :D
jvencius
In a van down by the river...
Not bad at all--I can't really tell where the wind noise is coming from, given that the SuperDuty has the aerodynamics of a brick, but if they do produce wind noise, I've never noticed it.
The ventshades, IIRC, cost me $65 or so for all four (I've got a CC) so they're not spendy at all. :D
y2kpsd
Member #11
ny
Turn signals that don't cancel out so quickly.
Plastic lens on speedo cluster that doesn't scratch so easily.
Larger tires
50 gallon fuel tank
Better cup holders front and rear
I agree, Greasable ball joints.
also, cargo tie-downs
Rebel Horseman
Minuteman Patriot
Holden, LA
A real diesel engine again. I'd love to see a Cummins or other manufacturer's I-6 stump puller in a Ford. Get rid of the high-revving play toy and give me a motor that will last half a million miles, get superb fuel mileage, and will drag the trailer off teh axles if I'm not careful.
Don't get me wrong, I like my 7.3 and it's a good pulling motor that will haul arse if needed...but my Cummins was an excellent truck. Hell, see if Ford and Navistar can adapt one of their engines to work in a SD like Cummins did with the 6BT engines for Dodge.
Also, quit charging more money for less product each year. Why must maufacturers take away little things in their option packages then turn around and raise the price of thsoe packages each year?
Brian [><]
ranger boy
Banned User
Brian [><]
I dunno I'm more than happy with my engine... :D
