FX4 Stickers
the_hammer
Gibsons British Columbia
Does anyone have any tips on how to remove the FX4 stickers from my box? I would like to take them off, but am not sure what would be a same method of removing the glue.
:thanks
Northeast Texas
i removed my 4x4 decals mine from my 250 a few years back. i gently peeled one edge and then applied liberal amounts of sopy water as i peeled them off.
after they are off wash the area real good then wax it.
speed kills take your time and go slow and steady they should peel right off
Wingdog
Thunder Bay, Ontario
A heat gun should work but don't heat it up too much or you'll burn the paint. A little heat and those things will roll right off.:sweet
i like to use a 2" wide chisel, and a 5lbs. sledge hammer.
start tappin at one end to get it started, and it should peel right off.
then use liberal amounts of touch up paint from K-mart to cover up the scratches. :thumbs
:sorry , i couldn't help myself.
i personally like my FX4 stickers, gives a little touch of color.
but what the others above said should work just fine.
05 Super Duty
SE PA
A hair dryer works well to help loosen up the adhesive...took mine off tonight.
police stroker
Dallas, Texas
Go by a body shop and they can use a eraser wheel to remove them. It's just a large rubber wheel that peels it off with no damage to the paint.
fordtrucker4life!
I work with waste
SE Michigan
I have one. Snap-on crud thug. Works great :sweet and I couldn't believe that it didn't harm the paint after how violent the wheel spins. :eek:
94f450sd
certified nutjob
plymouth,ma
amonia.get a corner lifted a little and spray straight amonia on it and wait a few minutes and start peeling and spraying.
