FX4 Stickers
I go with the HEAT method. I'v used a Hair Dryer, on LOW. Heat & peel as you go. If there is any glue left.. use some OOP's, on a rag.
Worked for me.. on a conversion Van that had "StarCraft".. on all 4 corners, the Hood & the Back doors, AND across the Windshield.. and 4 places inside Too.
Late Innings
Memphis, TN
I just peeled mine off on a somewhat chilly day.. it left very little glue residue and I dont recall if I got that with WD-40 or some good ole Ronson liter fluid. I did a meguaires 3 step very shortly after that. Looks great! Never really cared for the FX4 stickers. ( never really knew what they meant..??)
05 Super Duty
SE PA
They will peel off without heating them...they just come off easier with a little heat. The only residue that was left after mine came off was from the outside edge of the sticker. More a build up of dirt and wax than anything. Otherwise, there was nothing left as they came off as far as residue goes. I like the look of a clean truck, no badges or stickers, but alas I found that Ford pinned the F250 badge on the tailgate. There are three holes hidden by that badge. And I don't feel like filling them and painting the tailgate.
irish4x4
Mayor of Margaritaville
Reno, Nevada
They will peel off with heating them...them just come off easier with a little heat. The only residue that was left after mine came off was from the outside edge of the sticker. More a build up of dirt and wax than anything. Otherwise, there was nothing left as they came off as far as residue goes. I like the look of a clean truck, no badges or stickers, but alas I found that Ford pinned the F250 badge on the tailgate. There are three holes hidden by that badge. And I don't feel like filling them and painting the tailgate.
Yup. And those alignment pins are on your f250/350 fender badges too. The
powerstroke door badges peel right off though.
Fine69
Cranberry Twp,PA
i like to use a 2" wide chisel, and a 5lbs. sledge hammer.
start tappin at one end to get it started, and it should peel right off.
then use liberal amounts of touch up paint from K-mart to cover up the scratches. :thumbs
sorry , i couldn't help myself.
i personally like my FX4 stickers, gives a little touch of color.
but what the others above said should work just fine.
I agree with Bama, I like mine!
Fx4ord
Slidell La,(aka)The Dirty South
"StarCraft" man that is the Shizzznit. Why on EARTH would you want to remove a name like that. DUDE "StarCraft":hail
:sorry I could not resist.
