Gauge kits
CSIPSD
Bend, OR
Didnt know they made a combo trans/diff gauge? How do you like that? I assume its more expensive?
They dont, but you can run two senders to one gauge and then run a switch and switch back and forth as you want...
And just for fun, a pic of the cockpit...
commanderjjones
Knoxville, TN
It's always worked fine and I like it. Like I said, they didn't make a 4 gauge pillar back when I bought mine, so that was my only alternative to cram 4 gauges in. It was slightly more expensive than a single gauge, but not much......still less than the cost of 2 separate gauges. I can't remember what I paid for them....that's been over 10 years ago.:confused:
Who makes it? I have never seen one, be curious to see it.
Westach makes'm.. poke Westach
I almost bought one... but I like the mini toggle switch idea. Looks better, less pricey too :dunno
3 temps, from 1 gauge ? You betcha.
commanderjjones
Knoxville, TN
It might be a Westach gauge. It looks slightly different than the other 2 gauges. I'll post a pic' as soon as I can get my truck back....which might be a few weeks:doh:. Going from my Superduty to an Impala rental car is really sucking bad. I hope I don't have to tow anything for a few weeks. This ordeal has already made me miss the last weekend of deer season....of course, I guess I could've thrown a bloody deer in the back of that Impala:D.
Stroked68
This is FORD Country
Eudora, KS
I love your gauge set up! Definately cant have too many haha. I think I will have to do the toggle switch to use one gauge. Be cheaper for sure. What all gauges you have?
CSIPSD
Bend, OR
A pillar top to bottom
Exhaust Back Pressure 0-60
Boost Pressure 0-60
Left EGT 0-2000
Right EGT 0-2000
Dash Top
Water Injection Pressure 0-180psi
Overhead Pod left to right
Tranny temp 100-280
Rear diif temp 100-280
Oil temp 100-280
Coolant temp 100-280
Dash Suround
Drive oil Pressure 0-400
Intake air temp 0-240
Volts 10v-16v
Fuel level for the bed tank
Underdash left to right
Fuel pressure 0-100
Oil Pressure 0-100
Air Pressure 0-180
And a Scan Gauge on the steering column...
RSG
Savoy IL
...and what is below the ventilation controls in center, above the fuel/oil/air gauges?
Boost Pressure 0-60
Left EGT 0-2000
Right EGT 0-2000
Dash Top
Tranny temp 100-280
Oil temp 100-280
Dash Suround
Volts 10v-16v
Fuel pressure 0-100
Oil Pressure 0-100
Air Pressure 0-180
YIKES Joe ! Do you halfta do a Flight Phyical yearly, to stay Seat Qualed or anything ????? ;):lmao
You Gotr Go'in On Tho..... Gauge Wize. Not much you can't monitor.. fur shur ;tu;tu
