Got codes, what should I do first?
Capricious
Albuquerque,NM
I pulled these last night. Truck runs good until it gets up to operating temp then starts stumbling.
P0470-Exhaust back pressure sensor circuit malfunction.
P0478-Exhaust pressure control valve high input.
P0603-PCM processor keep alive memory (KAM) error.
P0676-Glow plug #6 circuit failure
P1316-Injector circuit/IDM codes detected
P1000- OBD II more driving needed.
Thanks,
Bobby
That IDM code raises my eyebrows, as does that #6 glow plug. Those are the first two I would look at, prolly the #6 GP first, make sure its not shorting the harness out.
Yes, if one of yoru glow plugs went south it may have begun to melt the connectors between the wire harness and he VC gasket.
