Grille Insert Questions
SeventyMach1
North Carolina
I have one of the "part chrome" grilles on my '99. The top half of the honeycomb part on the passenger side is busted out. I plan to get a new plain grille and paint it white (color of truck). I was then going to get some of those billet grille inserts (horizontal one's) and have them powdercoated black ...... then bolt them in.
My question is this .... do I need to even get a new grille? Basically, I just need to know "where" on the passenger side honeycomb does the insert bolt up. If I don't need to use the top half of that section to bolt the insert in, then I can keep my current grille & save some $$$.
So those of you that bolted these in, please post up. T.I.A.
Mike K
يساعد المعركة لحرية
Baghdad International Airport
Do you have a picture because i know i am lost.
Here is a picture of my grill, are you asking how this bolts in? I think we have the same style grill.
-Mike
SeventyMach1
North Carolina
We do have the same style grille.
There are 2 options out there. One is a billet insert kit (3 pieces I guess) that bolts into your existing grille. The other is a complete grille ..... already made with the inserts. I don't know which one you have.
So yes, if you have the 3 piece kit, I need to know how the passenger side piece bolts in (like the specific locations of the bolts). The top part of my honeycomb is broken out .... but if I can still bolt it in, that would be great.
Here is a pic. The red circle is the part that is busted out on mine .....
Mike K
يساعد المعركة لحرية
ohhh ok.... yes i have the 3 piece. There are two threaded rods that would go through the honey comb and then flat stock that connects the two. Even though your honeycomb is missing i still think there is enough there to hold it in place and you shouldnt tell anything is wrong once it is all together.
I have attached another picture that is a little clearer. If memory servies me right (and its not like i can just go outside and check :sorry ) the threaded rod is about the second bar from the top and the second bar from the bottom. And like i said, there is a piece of flat stock that connects to both threaded rods that just about goes the whole length of the grill piece and clamps it in place.
ohh i just found a picture of the grill before it was installed. It is the center piece but you get the idea.
-Mike
Whata250
Whata250
heath, TX
You can put either billet or stainless inserts to cover that up. I have stainless inserts in mine from http://www.cloudrider.ca/.
They clip behind the outer portions of the grill instead of the honeycomb part
whatabudro
Launched
If you use the one peice billet then no you don't need a new grill. You will trim away everything but the chrome from the ones I've seen.
