Hello everyone!
What have you got? Fill out your signature by going the the Quick Links above and fill it out. And :welcome4 Fordhorseplay!
Dave :)
Hello and Welcome to SSD.com, glad to have you here, Mr. Fordhorseplay!
Mooresville, In.
my name is Rob actually, i'm going to try to change it.
I recently purchased a 06 f-350 Harley Edition 4x4 CC SWB with 6-8 inches of lift, 37x12.50x 20 on 20x10 jesse james lawless wheels.
that being said, i have an issue with my truck. I am getting codes from the truck that I am trying to fix. any help would be appreciated.
B1000 PCM
P1832 T-case diff lock up sole volt
P1876 T-case 2wd sole volt
any one had this issue before?
I am thinking about replacing the electric motor on the transfer case but I wanted to see if anyone else has had the same problem and what they done to fix it.
thanks.
It looks like you have a bad solenoid in the transfer case electronics. Check or change that before go for the motor. B-codes mean nothing to me as I have no reference for them. And you are stuck with your user name; no changing that.
Dave :)
