HELP PLEASE!
tommydawg
hemet calif
hey guys im stuck here, my 97 7.3 all of a sudden just started losing power untill it just died all within about 2 miles , i did notice a check engine light but it didnt say on long, my buddy borrowed a scanner and I pulled 3 codes p0344, p1211, p01212, this is my work truck can anyone please help me before I lose my job and my mind, I changed the fuel filter, and have over 3000psi out of the hp oil pump could it maybe be a cam sensor? thanks
P0344 Camshaft Position Sensor Circuit Intermittent
I'd guess you lost the CPS then the 1211 and 1212 codes came in as a result of that.
P1211 Injector Control Pressure Sensor Above / Below Desired
P1212 Injector Control Pressure Not Detected During Crank
Yes, if you are looking at the front of the engine it will be at approx 10 o'clock in relationship to the crank. You'll need a 10mm on a ratchet to get her out.
