help....slave cyclinder, clutch
jopes
Wyoming
how does this thing work. I am about to drop the tranny on this and I am not seeing how it disconnects from the tranny.
sliding sleeve disconnect on the line
if you happen to break it, Ford offers a repair kit
jopes
Wyoming
not really understanding how that works, will peek @ it again to see if I understand.
you'll see the line going into a metal sleeve... that metal sleeve is actually two parts, one slides into the other... like a quick disconnect fitting on an air hose
what I'm getting at is, take the line off the slave, rather than take the slave off the transmission
jopes
Wyoming
I thoguht they were sealed units?
does this require re bleeding? I see no ports to bleed it out, and I see where the hose goes in the slave, but it does not look like any quick disconnect?
I should have asked first... nylon or steel line? Steel line should have a union nut at the slave... and yeah, you need to bleed it, but you bleed it by pumping it like a bazillion times.. (I think it's like 30-50 times)
jopes
Wyoming
thank god these clutch parts are light. I feel sorry for anyone who does this laying on the ground......
94f450sd
certified nutjob
plymouth,ma
i do them laying on the ground all the time.i hate lifts.
