hub ??
no-red 6 0
Senioritis
southmetro MN
can someone tell me on the '03s if the factory hub is COARSE or FINE thread?
need to get one ordered and am not sure if it is the 515020 OR the 515025 - fine or course!!
I am with atk, never heard of any threads on the hubs. Mine only have a snap ring holding them on.
no-red 6 0
Senioritis
southmetro MN
the four bolts for which it goes on????
if you don't have to re-order new studs, i therefore want to re-use mine and need to know if they are fine or coarse cuz i do not want to get the wrong kind.....
i know of the snap ring!!
You want the studs that hold on the SPINDLE, correct? I think they are coarse threads as they go into a casting and bolt up using coarse thread nuts.
no-red 6 0
Senioritis
southmetro MN
yes dave-
that is to what i am referring......BUT that brings up a good point (question in my mind) - do i have to replace the whole thing or just the center bearing part? cuz i think that would be cheaper - huh?
atk
Moderator
simcoe, ontario, canada
which bearing is shot, wheel bearing or bearing axle shaft rides on???? you should beable to reuse your old studs if you can get them out....
