Intermittent stalling 05 7.3 Australian
Powerstrokebloke
Brisbane Australia
Intermittent stalling 05 7.3 Australian, now with pics
Hi there guys,
Just experiencing some weird problems with my truck.
Its an 05 Australian with a 7.3
I did a full service on it a few weeks ago, oil and all filters, and ever since it has had an occasional cough, where it just loses all power for a second, and goes back to normal.
In the past few days it has developed into just cutting out totally, but only intermittently, like only 3 times, and it always fires straight back up easily.
Truck runs well, feels normal power wise.....
I have noticed though, having just installed a Banks Bullet under heavy throttle load, and with 6000lb plus in tow, it will bring up a check engine light....but turn ignition off, all gone, till the same conditions are met....
I don't know if the two are related, but thought it may be worth mentioning.
Thanks in advance for your help.
Matt
Frankenstien
Frankestien
South Prairie Wa.
Sounds like the Classic CPS symptoms... If you can pull the Check engine codes.... this would most definitely put you in the Ball park of what the issues may be.
JRJ04
Houston, TX
so it has the '05 exterior looks as well as interior styling, but the good ole' 7.3 power plant?
