Jerking Issues
99F250
I'm still having problems and not getting anywhere, my truck sometime jerks hard and the RPM's jump, other times it just stall's out, it throws the check engine light and also the SES light. I just replaced the fuel filter(No Water in fuel), the CPS, and the ICP sensor. Could the P1249 code or the P0470 code have anything to due with these issues. Code below are what keep coming up. :confused:
DTC P1249
wastegate
Control Valve
Performance
DTC P0344
CamShaft Position
Sensor A - Bank 1
CKT Intermittent
DTC P0478
Exhaust Pressure
Control Valve
Circuit Malfunction
DTC P0340
CamShaft Position
Sensor A - Bank 1
DTC P0470
Exhaust Pressure
Sensor
Circuit Malfunction
DTC P1211
Inj Cntrl Press
Beyond Desired
(Engine Running)
99F250
I took my diablo chip out, truck doesn't stall or jerk anymore (3 days). Not throwing any codes either. Hopefully it was just chip related.
castellscl
