jiggle jiggle at 40
neil_04
houston, TX
when im doing about 41 or 42 and slowly accelerate my truck wiggles yall think my carrier bearing is going out i got 203 k on my orig. one
Frankenstien
Frankestien
South Prairie Wa.
Wiggle... or vibration. Wiggles are most commonly caused by caster being improperly set, next... and most likley (if in the Steering) would be Ball joints. if the Carrier bearing may cause some harmonic vibes. this can some times be diagnosed by adding a small shim in the Rubber that holds the bearing, mind you this is not a fix.... this will either amplifiy or remove the symptom. Hope this helps.... also just noticed you have a 4X2... check your tie rod ends for exessive play.
neil_04
houston, TX
i dont think its the front end it could be, i had the front end done a while back new ball joints and tie rods and bushings i will try the test on my carrier bearing thanks for the help
Tbar
SDD STAFF/Moderator
Just for grins check your lug nuts also...........
Tbar
neil_04
houston, TX
i had the tires rotated to make sure it wasnt them so the lugs arent the cause its kinda the same wiggle though that happened to me in my old truck discount forgot to tourque them down i made them pay for a new set of lugs cause i only had 2 left
Milly333
