Leaf spring separating pads?
orion_134
Woodbridge, VA
I need a part number for the pads between the individual leaf springs of my 99. Ford found them but says they arn't serviceable...anyone know better?
Jesse
Frankenstien
Frankestien
South Prairie Wa.
Hello Marine,
I replaced mine with a thin piece of Rubber. About the thickness of an inner tube, Did this around 40 K ago, they seem to be holding up well, plus it seemed to quiet the ride down by just a bit. to install I jacked the truck up, to the load off of the suspension, used a tire iron to separate the spring then inserted the rubber square on top of what was left of the pad.
orion_134
Woodbridge, VA
Sounds like a good fallback plan. Mine are completely gone and have been for some time now.
Jesse
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
There is a Ford part number for a plastic pad/separater for the front springs. I'll see if I can find out what that number is. Never heard of anything for the rears.
JRJ04
Houston, TX
hey when you noticed they were bad were you getting a squeaking kind of noise from the front end when you rock the truck back and forth? I've got that and a kind of knocking sound and I'm wondering if this could be it?:dunno
JRJ04
Houston, TX
interesting...I guess I need to look and see if mine need to be replaced too. that knocking sound is annoying!
