Help Needed leaking pinion seal
jherman
nevada
i got the truck back, $460.00 to set a new crush sleeve, good thing was the bearings were like brand new, it was an expensive lesson but i am smarter for it.
thanks to everybody
bigrigr
Real trks hv 3 pdls
provo, utah
In my experience, it takes a hE*& of a lot to crush the sleeve, if you hammered on it with a big gun, you might get it to move, but not if you just cranked down the nut. When a new sleeve was installed, i had a hardtime getting the sleeve to crush to get the pinion turning torque right. JMO but i would gun it till the nut stops turning and let off. Then like said before, just stake the nut with a chisel and hammer in a couple spots. A major teardown seems a little much for just a seal replacment.
