Let's talk garage doors-------
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
Last week, Mrs TG, the puppy & I went camping to High Cliff State park near Appleton, WI. Quite literally, when we were pulling out of the driveway, I punched the button on the door opener. I glanced in the mirror to make sure it was closing. Normally, what you want to see are various things either straight up & down or back & forth. Well, when I looked, going across the garage opening was a big white object at about a 45* angle. -mad
I was lucky that it didn't come down on the wife's car and left me enough room to get it out into the driveway.
As it turned out, one of the springs broke. I had the type of door mechanism where the two springs are stretch type springs and are along the upper roller rails. When the one spring broke, there wasn't anything to support that side of the door and it decided it wanted to go down faster than the other side. In the process, all the door panels got mangled, trashing the entire door. I managed to remove a couple of panels and un-jam the others. With a little bit of "not so suttle" persuation, I got everything back in place so at least the garaged was closed up, and off camping we went.
While camping, some friends came out for a visit. It just so happens, the husband used to work for Overhead Door. He told me that when choosing a garage door, the style with the twist style torsion spring is the best way to go. The type I had were not only more problem prone, but down right dangerous. If a spring lets go, it will do what mine did. Sometimes the broken spring pieces will go flying causing damage and even possible injury if there is not a safety cable going thru the center of the spring.
The twist type or torsion spring is safer because if it breaks, the garage door will still come down evenly. The lift cable drums are on opposite ends of a single shaft. The torsion spring is mounted on that shaft. So if the spring breaks, it stays on the shaft.
I bought a new door and have just finished the installation. The spring had a windup mechanism where you could windup the spring with an electric drill. :sweet I still have to install some bracing and hook up the door opener. I thought it would be a tougher job than it was, especially since I did it solo and it was a 16' wide door.
Congrats on the new door!
(not really crazy about how you went about getting it, though)
RoyBoy
Diesel Dork
central WI
Yeah, torsion springs are the way to go. I just got the doors in for my new shop, the biggest one is 22'w x 18'H. You should see them big bad springs for that thing :eek:
I went with Hass commercial doors, they have a line that is 3" thick, R25.8 very nice doors :sweet
Had one of those un-cabled springs let loose several years ago, Just After I had closed the garage door and stepped in the house. I thought something Blew Up :eek::eek:
The >shrapnel< tore a cabnet door off it's hinges and destroyed a light fixture.
Replaced the whole works with a Roll-up type, from Overhead Door also.
Sure is something to think about, if anyone has the older style springs ??
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
That's kinda what I was thinking when I started this thread.
I'm in the process of fabbing up a support bracket to attach the door opener to. I'm taking a short break before I go out & fire up the ol' Miller AC/DC stick welder.
Guess when I'm all done I can finally unload the truck from camping. :eek:
Rather difficult to put everything back in the garage when the door don't work. :innocent
screw it...
air it out and leave it packed..
that way you have it for next time...
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
screw it...
:lmao:lmao:lmao:lmao:lmao:lmao:lmao
I just found out we're going again, this time to visit Mrs. TG's sister & family.
So JL, you're closer to what the plan may be than you realize. :lmao:lmao
no-red 6 0
Senioritis
southmetro MN
mine has the roll up rod above the opening w/ the springs on each side w/ a cable going thru it!!!!!!!!!!!!!!!!
couldn't figure out why door was acting so funny and 'had' to call the door guy - only 3 blocks away anyway....took him a bit to find the issue - spring did break and slid back into place, he had to wiggle each spring to see if one was broke....he said it was lucky we had the cable thru it or it would have been ugly....said they are good for 10,000 cycles.....lets see, what number was i on???:doh:
