Leveling kits
bigmike33
Kitimat, BC
Hi I am new to this site so bear with me. I just bought my first diesel. It is a 2004 F350 Lariat turbo diesel FX4. Anyhow I want to install a 2 inch leveling kit. What should I buy? If you just block it will it be hard on the u joints and front end or should I buy the entire kit/ NEED HELP
Buffs F-350
New Jersey U.S.A
NEVER put blocks on the front of a leaf sprung truck. It is dangerous and puts way to much stress on the front end. There plenty of companys making add a leaf kits that are not that expensive and much safer. Dont forget to buy the proper trac bar drop and pitman arm.
'57turbo
Phx,AZ
Are you sure you neeed 2"? use a floorjack to raise te front or the truck.
Measure before and raise the truck the 2" and step back to see if it is what you are looking for.
I only put a 1" block on my truck to level it.
I would be more worried about the track bar than the u-joints if you only do blocks.
i put a 1.5" add-a-leaf leveling spring on my 2004 F350 SRW, and it made it look just right. it still has just enough rake to the front end. :thumbs
no-red 6 0
Senioritis
southmetro MN
i still gotta put on my 2" aal. sitting on the bench. manufacture told me no extra brackets needed til a 3" or more lift is added..fwiw
Milly333
