Question Low Sulphur Fuel Additive?
JFORE
Maryland
I have an 97 F-350 should I be using a additive with the low sulphur fuel? I was considering the Stanadyne Perforance formula is anyone using this or have other suggestions?
Stanadyne has been around for quite a while and is a good respected name.
Another that many are happy with has been the diesel kleen that is available at Wal-mart
There's a great debate on if you need to and/or should run the additives, in general I don't I do periodically run some B-100 which is another option that you can use if available to add the lubricative properties back to the fuel.
One that I've seen gaining popularity is adding ashless 2 stroke oil.
people that run TCW3 two-cycle oil (myself included) report less injector rattle from the top end of the engine.
I run Diesel Kleen every other tank. Now they make a cute little pint bottle that treats 25 gallons, instead of the 48 oz'er that you had slop around in the bed for three fill-ups...
ono_55
Northern Calif
I run diesel kleen i use the 48oz put half the bottel in each tank pick up 2 miles per gallan that way. It also smells good to.
MONSTERPLOW
Cloud Booster 500HP
I 95n.b. 1/10 Keystone State
as long as it's well filtered,regular heating oil has all the lubricants that motor was meant to handle,and need, 500 ppm is what yer looking for,and at a reaonable price
but the tree huggers will tell you different
