lower floor panel floor console
Wood County Tx
anybody have pictures of a floor console that would go infront of the center floor console.
I need an idea on how and where to mount the invertor. so its secure and accessible
Fire1
Certified Diesel Driver
I have one I made for my AIC, check the webshots in my sig. It has changed a little from the pics, not much.
Fire1
I could take some measurements, I just kind of made it on the fly. It actually just sits there. I did put some of the stiff velcro on each side to grip the carpet. I does not move at all.
I used some of that foam core craft poster board stuff to make patterns and to get the floor contour for each side piece. They may still be floating around in the garage somewhere.
Wood County Tx
I have some of that core stuff hanging around. I will look at it this evening iffin its not to darn cold.
The invertor weighs a couple pounds so i need to bolt it down
maybe I can work a mount into it to hold teh laptop at a reasonable level
THanks
Fire1
The console itself is made of 3/8" (I think) MDF on the sides and the top is 1/4" MDF. I did a little fiberglass resin to clean it up prior to painting. I'm wanting to build a new one w/ some mods and mostly fiberglass construction. Just have not found the energy or time.
Wood County Tx
mdf should work fine
i am going to cover it with a material similiar to the headliner,
an intake vent hole and put the outlets on the passenger side.
Fire1
I bet that will work dandy. Good luck!
Nice work there Robert :sweet You going to try and fabricate something up in the near future?
