Wow I guess I havent been on here for a long time, Ive moved and had the truck was stolen and recoverd this past summer.. Anyways when the truck was stolen over the summer and recoverd 7 days later the Pass beam was bent along with the radius arm, so all that needed to be replaced, I had them install the DJM lowering beams since the whole kit was cheaper than one factory I beam.. I also finally got around to lowering the rear about 5 inches by just unbolting the rear setup and rebolted to the height I wanted, if you wonder how, its because I have an aftermarket rear suspension setup that doesnt use shackles, instead I have polyproproline rubber bushings bolted together and you just flop things around and or reconfigure them.. I will get new picks and post them up when I get a chance..
