Manual locking hubs
airdrew99
Living for Him
Brandon, MS
I have a 2000 PSD with manual transfer case and manual locking hubs. I have an uncle that owns powerstrokes also. He seems to think that if I engage the 4WD (on the transfer case), then the manual locking hubs have a feature that will automatically engage. He said they can also be manually locked, but it's not necessary. Does this sound right to anyone? Or do I have to manually lock the hubs every time I need 4WD?
Drew
the factory hubs on the Electronic Shift On the Fly ("ESOF") are vacuum actuated with a manual override.
When they work. :doh:
After resealing the knuckles on mine & having them fail again, I threw them in the trash and put on a set of Warns.
Get under the truck and look at the back side of the hub, if you see a 1/4'' tube coming off the top backside of the hub then you have a vacuum operated hub, if there is no tube then you need to manually lock the hubs.
if you have a manual transfer case, then your hubs are going to be manual as well and do not have an automatic lock feature.
RSG
Savoy IL
I gave mine away and put in Warns, couldn't part w/ the $$$ for ESOF replacement on just 1 wheel.
But..when they work, they are great.
Kirbco
kirbco
berlin ct
Looking to buy manual hubs
I also have a 1999 SDD with SOTF 4wd. Bad seal on one side, just put in ball joints and axle u-joints. When I need 4wd I need it, I can't just hope the vacuum system is working.
Anyone out there know the part number and the best place to buy Warn manual hubs?
Who else makes hubs and do I need a concersion kit?
I don't think I do as it is part time.
Hubs have locked and auto feature and barely move with broken plastic.
RSG
Savoy IL
In response to Kirbco, does anyone know roughly the cost of some Warn manual hubs?
Had a shop do it for me: $330 for 2 hubs + $175 installation 1.5 years ago, including repacking all bearings, replacing all seals, etc. IRC it was about $400+ for 1 auto hub replacement cost. Sorry, no part no's in my file.
Ford0273
Littleton, Colorado
Replacement Hubs
Check out dynatrac.com, they have a conversion kit that will also get rid of the unserviceable unit bearing. You'll get new spindles, hubs w/ timken bearings, outer axle shafts, manual locking hubs and more. It's pricey, but if you plan on really keeping this truck, it adds peace of mind. I don't work on my truck as much as I used to but I installed the kit in just over half a day. Every thing in the kit was top notch.
Milly333
