Help Needed miss, stumble, and dies
proudvet
Pensacola,FL
good batteries and new cps = no good
o.k. I went and got another cps, this one from ford. I put it on and changed the oil. The truck ran like a champ for about 5 minutes then started surging badly and died. I let it sit for a few minutes and then limped home. Almost forgot, the batteries are good. Any more ideas? Thanks.
Yeah.
Injector Pressure Regulator (IPR)
read the other guys thread, Brandon tells you how to access and service it..
I was thinking might want to start by making sure the ICP sensor in the front of the left head doesn't have a puddle of oil & snot in the connector...
Yeah.. what JLD said, would be the next thing to check.
proudvet
Pensacola,FL
ICP didn't have oil on it and changed the IPR. The same thing happens. Runs very rough and shuts down.
From here, two things to go check; Have access to some professional grade tools?
Put a fuel pressure gauge on it, and watch the pressure when it dies...
Or put a scanner on it and look at data like
injector pulse width
ICP pressure
MAP data
another quick check you might do.. there's a plug in the back of the high-pressure oil pump (HPOP) next to the fuel bowl.. next time it quits, pop that out real quick and see where the oil level is..
proudvet
Pensacola,FL
Fixed
Thanks for the help guys. I finally towed it to the shop. It ended up being the number 3 injector. The o rings were pretty bad. We pulled the rest of the injectors to look at their o rings and they were fine. Replaced and running. Thanks for the help.
;tu
DennyF250
United States
My 2006 6.0L has been starting rough the last couple of mornings (really black exhaust, rough running, eventually smooths out and performs normally all day, engine light on). Today it won't start. Tries to start roughly, but won't. Any ideas where to start?
The FICM (Fuel Injection Control Module) maybe dead or deing. You need to get a scanner to find out what codes are stored in the PCM. They will give you a clue. Any good shop should be able to scan your truck.
