MPG change with weather
NDsuperduty
Kingwood, TX
Does MPG in diesel change quite a bit when it gets cold? I was getting about 17, and since the weather got cold in houston I got around 15 on two different tanks. Is it the weather or should I be worried something is wrong.
Not to Worry. The oil companies start making "Winter Blend" #2 ULSC diesel in about October. It's not as Efficient a fuel as strait # 2, so our engines are not as efficient. MPGs go down some.
As long as the 15 (or so) MPG stays the same ? Not to Worry
NDsuperduty
Kingwood, TX
i figured that was it. My gasoline truck used to chang
when it was winter, but never 2mpg which is why i worried a little.
Wingdog
Thunder Bay, Ontario
Don't forget your warm up time too. Even if you only do it for a few min each time you go somewhere it all adds up.
Zookie400
I WANNA GO FAST
wallingford, CT
if your engine doesnt heat up all the way it takes more fuel to get the same power output as a hot engine.
black_cloud_stroker00
GO BIG RED!!!
Bellevue, NE
I read somewhere that 10 minutes of idling is about equal to 25 miles driven.
I have a question, most of the stations that I fill up at, don't advertise whether its #1 or #2 diesel, and the "kid" behind the counter never knows. Is it pretty safe to say that everyone switches to the winter blend.
Buffs F-350
New Jersey U.S.A
#1 is kero #2 is everything from usld to heating oil.
Milly333
