Need an OASIS report
bbressler
Happy, TX
Could one of you fellers hook me up with an OASIS report?
1FTNW21F51EA15021
Thanks!
Toptech
West Virginia
VEHICLE DESCRIPTION
2001 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
7.3L TURBO - DI
TRANSMISSION
4R100 4SP (DIESEL) AXLE CODE
ENGINE CALIBRATION
1F719S0A
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL CONTACT
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
09/15/2000 BUILD DATE
08/14/2000 SALE MILEAGE
00120
OUTSTANDING FIELD SERVICE ACTIONS
07S57
CAMSHAFT POSITION (CMP) SENSOR INSPECTION / REPLACEMENT
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
NO RECENT REPAIR HISTORY ON VEHICLE
Click Here for Full Warranty History
| On-line 1878
END OF OASIS REPORT FOR 1FTNW21F51EA15021
Toptech
West Virginia
Here is the warranty history also.
VIN VEH LINE MKT DERIV BODY CAB VER SERIES DRIVE TYPE PLT CD TRS CD ENG CD PROD DATE WARR DATE SELLING DEALER SELL CNT TIS WCC CPSC_6 PREF BASE SUFF CCC CD DIST(Miles)
1FTNW21F51EA15021 T/F7 F T/BC T/BD T/E A1 T/DQ T/DS 14-AUG-2000 15-SEP-2000 152250 USA 0 * * * * * * * 153
AWS Claim Key: 104571 Trx Code: TDE Labor Hrs: 0
Dlr Cd-Sub Cd: 07037 - * Name: MULLIN FORD-MERCURY Ph: 940-9373626 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:11-SEP-2000 Doc #:04909601
Tech Comments: REFINISH LH FRONT FENDER, SCRATCHED.
AWS Claim Key: 104572 Trx Code: TDE Labor Hrs: 0
Dlr Cd-Sub Cd: 07037 - * Name: MULLIN FORD-MERCURY Ph: 940-9373626 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:11-SEP-2000 Doc #:04909602
Tech Comments: REFINISH LH REAR DOOR, SCRATCHED.
1FTNW21F51EA15021 T/F7 F T/BC T/BD T/E A1 T/DQ T/DS 14-AUG-2000 15-SEP-2000 152250 USA 7 5H01 04***X YC3Z 5586 AA N50 30 24113
AWS Claim Key: 1031807 Trx Code: E84 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 03565 - * Name: GENE MESSER FORD LINCOLN MERCURY Ph: 806-3557471 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:21-MAR-2001 Doc #:11054402
Cust Comments: NOISE IN FRONT END WHEN GOING OVER BUMPS
Tech Comments: CC 30 ROAD TEST UNABLE TO DUPLICATE AT THIS TIME CK FT LEAF SPRING SPACERS SLIGHTLY WORN REPLACED ALL FOUR SPACERS TECH 218
1FTNW21F51EA15021 T/F7 F T/BC T/BD T/E A1 T/DQ T/DS 14-AUG-2000 15-SEP-2000 152250 USA 14 2B01 030701 F7TZ 12K073 A D21 42 47182
AWS Claim Key: 5003788 Trx Code: S07 Labor Hrs: 1
Dlr Cd-Sub Cd: 02422 - * Name: CHARLES LANGEN FORD Ph: 806-2448511 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:06-NOV-2001 Doc #:116576A
Cust Comments: D21 ENGINE STALL WHILE DRIVING WONT STAR UNTIL IT SETS
Tech Comments: NGS TEST CONT CODE P0344 PINPOINT TEST AND REPLACECRANK SENSOR RETEST OK
1FTNW21F51EA15021 T/F7 F T/BC T/BD T/E A1 T/DQ T/DS 14-AUG-2000 15-SEP-2000 152250 USA 14 * * * * * * * 47182
AWS Claim Key: 5003789 Trx Code: 01S24 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 02422 - * Name: CHARLES LANGEN FORD Ph: 806-2448511 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:06-NOV-2001 Doc #:116576B
Cust Comments: ADD RECALL 01S24 WIPER MOTOR GEAR COVER
Tech Comments: REMOVE WIPER MOTOR INSPECT AND REPLACE COVER
1FTNW21F51EA15021 T/F7 F T/BC T/BD T/E A1 T/DQ T/DS 14-AUG-2000 15-SEP-2000 152250 USA 40 2E06 030008 F81Z 9E527 CRM D13 42 84650
AWS Claim Key: 16869944 Trx Code: E72 Labor Hrs: 12.1
Dlr Cd-Sub Cd: 06977 - * Name: H & H FORD Ph: 580-5442232 St:OK Ctry Cd: USA Reg Cd: NA Repr Date:05-DEC-2003 Doc #:03316701
Cust Comments: ENGINE IDLES & RUNS ROUGH.
Tech Comments: RUN PERFORMANCE DIAGNOSTICS. R&R 1 INJECTOR AND THE OTHER 7 O RINGS.
1FTNW21F51EA15021 T/F7 F T/BC T/BD T/E A1 T/DQ T/DS 14-AUG-2000 15-SEP-2000 152250 USA 46 1E03 031102 * 6148 * D42 30 99238
AWS Claim Key: 18989950 Trx Code: PRM Labor Hrs: 14.3
Dlr Cd-Sub Cd: 02422 - * Name: CHARLES LANGEN FORD Ph: 806-2448511 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:23-JUN-2004 Doc #:124924B
Cust Comments: ENGINE HAS LOWE POWER RUNS ROUGH
Tech Comments: PISTON RINGS WORN CYLINDER WALLS SCORED HEAD VALVES BURNED REPLACED ENGINE PER DISTRICT REP ON PROGRAM PRM
1FTNW21F51EA15021 T/F7 F T/BC T/BD T/E A1 T/DQ T/DS 14-AUG-2000 15-SEP-2000 152250 USA 49 2E06 030008 F81Z 9E527 CRM D13 42 112541
AWS Claim Key: 18992495 Trx Code: SPW Labor Hrs: 7.8
Dlr Cd-Sub Cd: 06977 - * Name: H & H FORD Ph: 580-5442232 St:OK Ctry Cd: USA Reg Cd: NA Repr Date:09-SEP-2004 Doc #:03320501
Cust Comments: ENGINE RUNS ROUGH & MISSES.
Tech Comments: VERIFY CONCERN. RUN PERFORMANCE DIAGNOSIS. PP TESTS NA11, NA12, NA23. INSTALL RETAINER ON LH HARNESS & RE RUN TESTS.STILL MISSES. PP NA25 & NA26. CHECK COMPRESSION. REPLACE #4 INJECTOR. VERIFY REPAIR.
MBRPCrazyford
Eat Some Smoke
Harrisburg, PA
can someone give me one too? VIN is 1FTHF36FXVEC95035. Thanks in advance. How do you get an oasis report. I tried lookin for it but couldn't find anything.
Toptech
West Virginia
Sorry MBRPCrazyford, OASIS only goes back ten model years. But you do have a cam sensor recall.
Errors
VIN OUTSIDE OF SUPPORTED 10 MODEL YEAR RANGE
ALL APPLICABLE FIELD SERVICE ACTIONS WILL DISPLAY
ARN MESSAGES
07S57
EXTENDED COVERAGES
| On-line 1878
END OF OASIS REPORT FOR 1FTHF36FXVEC95035
MBRPCrazyford
Eat Some Smoke
Harrisburg, PA
ok thanks. How do you get an oasis report anyhow? Also, is there any other site that I can get a good detailed report for free? Yeah, I already replaced the CPS. Thaanks for checkin though. Really appreciate it!!
Toptech
West Virginia
As far as I know, you have to be an employee of ford or a ford dealer to have access.
